    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3966
    • M
      maponarooo @veye_xumm last edited by maponarooo
      @veye_xumm And this log is right?
      $ dmesg | grep veye
      [ 26.415448] veyecam: loading out-of-tree module taints kernel.
      [ 26.418410] veyecam 9-003b: probing v4l2 sensor
      [ 26.418573] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
      [ 26.430446] veyecam 9-003b: probe failed VEYECAM_MODEL_ID_ADDR
      [ 26.431893] veyecam 9-003b: board setup failed
      [ 26.433188] veyecam 10-003b: probing v4l2 sensor
      [ 26.433346] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
      [ 26.444597] veyecam 10-003b: camera id is veyecam
      [ 26.450485] veyecam 10-003b: sensor is IMX385
      [ 26.451703] veyecam 10-003b: board type is ONE board
      [ 26.453870] tegra-camrtc-capture-vi tegra-capture-vi: subdev veyecam 10-003b bound
      [ 26.458594] veyecam 10-003b: Detected VEYECAM sensor
        @maponarooo said in IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera:
        Yes, the board have 2 mipi csi interface ,you connect just one camera.
        • M
          @veye_xumm I have posted this matter at the nvidia forum site.
          https://forums.developer.nvidia.com/t/xavier-nx-with-jetpack5-01dp-cant-play-veye-mipi-imx385-camera/223524
          • M
            @veye_xumm By any chance, does the IMX385 camera firmware version matter?
              I do not think so.
              • M
                @veye_xumm NVIDIA has replied, but I don't know the meaning...
                Pls explain what they say...
                **Please collect the trace log to check.
                Also be aware below for r35 release.
                Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
                An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
                You can calculate the output data rate with the following equation:**
                https://elinux.org/Jetson/l4t/Camera_BringUp
                  @maponarooo
                  • M
                      @maponarooo
                      • M
                        alt text
                        alt text
                        New clock: GstSystemClock
                        Additional debug info:
                        Buffer pool activation failed
                        Caught SIGSEGV
                        Waiting for EOS...
                        What do I do?
                          @maponarooo
                          Please try
                          dmesg
                          check if any errors.
                          • M
                            What's the matter?
                            $dmesg
                            [ 22.356665] handlers:
                              @maponarooo
                              • M
                                Caught SIGSEGV
                                Waiting for EOS...
                                After, dmesg logs....
                                $dmesg
                                [ 153.865630] Call trace:
                                quad@quad-nx:~$
                                  @maponarooo
                                  Here is my suggestion that
                                  • M
                                    @veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
                                    I think this is software problem....
                                    • M
                                      @veye_xumm The manual is something wrong...
                                      Pls check.
                                      3.5.3 Download the bsp package to the Jetson board
                                      On Jetson Board:
                                      wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                      Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                      tar -xzvf nvidia_jetson_veye_bsp.tgz
                                      But...
                                      $ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                      --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                      Resolving github.com (github.com)... 20.200.245.247
                                      Connecting to github.com (github.com)|20.200.245.247|:443... connected.
                                      HTTP request sent, awaiting response... 302 Found
                                      Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
                                      --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
                                      Reusing existing connection to github.com:443.
                                      HTTP request sent, awaiting response... 404 Not Found
                                      2022-08-15 20:03:06 ERROR 404: Not Found.
                                        @maponarooo
                                        Thank you for the reminder, I've modified it.
                                        The file should have a tar.gz suffix instead of tgz.
