    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3966
      @maponarooo
      • M
        maponarooo @veye_xumm last edited by
          @maponarooo
          • M
            maponarooo @veye_xumm last edited by maponarooo
            alt text
            alt text
            New clock: GstSystemClock
            Additional debug info:
            Buffer pool activation failed
            Caught SIGSEGV
            Waiting for EOS...
            What do I do?
              @maponarooo
              Please try
              dmesg
              check if any errors.
              • M
                What's the matter?
                $dmesg
                [ 22.356665] handlers:
                  @maponarooo
                  • M
                    Caught SIGSEGV
                    Waiting for EOS...
                    After, dmesg logs....
                    $dmesg
                    [ 153.865630] Call trace:
                    quad@quad-nx:~$
                      @maponarooo
                      Here is my suggestion that
                      • M
                        @veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
                        I think this is software problem....
                        • M
                          @veye_xumm The manual is something wrong...
                          Pls check.
                          3.5.3 Download the bsp package to the Jetson board
                          On Jetson Board:
                          wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                          Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                          tar -xzvf nvidia_jetson_veye_bsp.tgz
                          But...
                          $ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                          --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                          Resolving github.com (github.com)... 20.200.245.247
                          Connecting to github.com (github.com)|20.200.245.247|:443... connected.
                          HTTP request sent, awaiting response... 302 Found
                          Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
                          --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
                          Reusing existing connection to github.com:443.
                          HTTP request sent, awaiting response... 404 Not Found
                          2022-08-15 20:03:06 ERROR 404: Not Found.
                            @maponarooo
                            Thank you for the reminder, I've modified it.
                            The file should have a tar.gz suffix instead of tgz.
