    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3968
      @maponarooo
      Sorry, I have not encountered this problem, this gstreamer command works just fine in our case.
      The 5.0.1DP version is unstable and has many bugs. NVIDIA should release a stable version soon, within a day or two, as far as I know.
      You can submit the problem to nvidia's forum, but I guess they won't give a solution and will make you wait for the next version. That's what I suggested.
      • M
        maponarooo @veye_xumm last edited by
        @veye_xumm Oh! No.............
        I have already build my applications all on JetPack5.01DP.
        Why this is so complicate?
        I can't wait new version....
        • M
          maponarooo @veye_xumm last edited by maponarooo
          @veye_xumm And this log is right?
          $ dmesg | grep veye
          [ 26.415448] veyecam: loading out-of-tree module taints kernel.
          [ 26.418410] veyecam 9-003b: probing v4l2 sensor
          [ 26.418573] veyecam 9-003b: tegracam sensor driver:veyecam_v2.0.6
          [ 26.430446] veyecam 9-003b: probe failed VEYECAM_MODEL_ID_ADDR
          [ 26.431893] veyecam 9-003b: board setup failed
          [ 26.433188] veyecam 10-003b: probing v4l2 sensor
          [ 26.433346] veyecam 10-003b: tegracam sensor driver:veyecam_v2.0.6
          [ 26.444597] veyecam 10-003b: camera id is veyecam
          [ 26.450485] veyecam 10-003b: sensor is IMX385
          [ 26.451703] veyecam 10-003b: board type is ONE board
          [ 26.453870] tegra-camrtc-capture-vi tegra-capture-vi: subdev veyecam 10-003b bound
          [ 26.458594] veyecam 10-003b: Detected VEYECAM sensor
            @maponarooo said in IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera:
            Yes, the board have 2 mipi csi interface ,you connect just one camera.
            • M
              @veye_xumm I have posted this matter at the nvidia forum site.
              https://forums.developer.nvidia.com/t/xavier-nx-with-jetpack5-01dp-cant-play-veye-mipi-imx385-camera/223524
              • M
                @veye_xumm By any chance, does the IMX385 camera firmware version matter?
                  I do not think so.
                  • M
                    @veye_xumm NVIDIA has replied, but I don't know the meaning...
                    Pls explain what they say...
                    **Please collect the trace log to check.
                    Also be aware below for r35 release.
                    Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
                    An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
                    You can calculate the output data rate with the following equation:**
                    https://elinux.org/Jetson/l4t/Camera_BringUp
                      @maponarooo
                      • M
                          @maponarooo
                          • M
                            alt text
                            alt text
                            New clock: GstSystemClock
                            Additional debug info:
                            Buffer pool activation failed
                            Caught SIGSEGV
                            Waiting for EOS...
                            What do I do?
                              @maponarooo
                              Please try
                              dmesg
                              check if any errors.
                              • M
                                What's the matter?
                                $dmesg
                                [ 22.356665] handlers:
                                  @maponarooo
                                  • M
                                    Caught SIGSEGV
                                    Waiting for EOS...
                                    After, dmesg logs....
                                    $dmesg
                                    [ 153.865630] Call trace:
                                    quad@quad-nx:~$
                                      @maponarooo
                                      Here is my suggestion that
                                      • M
                                        @veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
                                        I think this is software problem....
                                        • M
                                          @veye_xumm The manual is something wrong...
                                          Pls check.
                                          3.5.3 Download the bsp package to the Jetson board
                                          On Jetson Board:
                                          wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                          Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                          tar -xzvf nvidia_jetson_veye_bsp.tgz
                                          But...
                                          $ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                          --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                          Resolving github.com (github.com)... 20.200.245.247
                                          Connecting to github.com (github.com)|20.200.245.247|:443... connected.
                                          HTTP request sent, awaiting response... 302 Found
                                          Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
                                          --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
                                          Reusing existing connection to github.com:443.
                                          HTTP request sent, awaiting response... 404 Not Found
                                          2022-08-15 20:03:06 ERROR 404: Not Found.
                                            @maponarooo
                                            Thank you for the reminder, I've modified it.
                                            The file should have a tar.gz suffix instead of tgz.
