    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3972
    • M
      maponarooo @veye_xumm last edited by maponarooo
      @veye_xumm NVIDIA has replied, but I don't know the meaning...
      Pls explain what they say...
      **Please collect the trace log to check.
      Also be aware below for r35 release.
      Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
      An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
      You can calculate the output data rate with the following equation:**
      https://elinux.org/Jetson/l4t/Camera_BringUp
        @maponarooo
        • M
            @maponarooo
            • M
              alt text
              alt text
              New clock: GstSystemClock
              Additional debug info:
              Buffer pool activation failed
              Caught SIGSEGV
              Waiting for EOS...
              What do I do?
                @maponarooo
                Please try
                dmesg
                check if any errors.
                • M
                  What's the matter?
                  $dmesg
                  [ 22.356665] handlers:
                    @maponarooo
                    • M
                      Caught SIGSEGV
                      Waiting for EOS...
                      After, dmesg logs....
                      $dmesg
                      [ 153.865630] Call trace:
                      quad@quad-nx:~$
                        @maponarooo
                        Here is my suggestion that
                        • M
                          @veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
                          I think this is software problem....
                          • M
                            @veye_xumm The manual is something wrong...
                            Pls check.
                            3.5.3 Download the bsp package to the Jetson board
                            On Jetson Board:
                            wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                            Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                            tar -xzvf nvidia_jetson_veye_bsp.tgz
                            But...
                            $ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                            --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                            Resolving github.com (github.com)... 20.200.245.247
                            Connecting to github.com (github.com)|20.200.245.247|:443... connected.
                            HTTP request sent, awaiting response... 302 Found
                            Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
                            --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
                            Reusing existing connection to github.com:443.
                            HTTP request sent, awaiting response... 404 Not Found
                            2022-08-15 20:03:06 ERROR 404: Not Found.
                              @maponarooo
                              Thank you for the reminder, I've modified it.
                              The file should have a tar.gz suffix instead of tgz.
