    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3602
      @maponarooo
      • M
        maponarooo @veye_xumm last edited by maponarooo
        alt text
        alt text
        New clock: GstSystemClock
        Additional debug info:
        Buffer pool activation failed
        Caught SIGSEGV
        Waiting for EOS...
        What do I do?
          @maponarooo
          Please try
          dmesg
          check if any errors.
          • M
            What's the matter?
            $dmesg
            [ 22.356665] handlers:
              @maponarooo
              • M
                Caught SIGSEGV
                Waiting for EOS...
                After, dmesg logs....
                $dmesg
                [ 153.865630] Call trace:
                quad@quad-nx:~$
                  @maponarooo
                  Here is my suggestion that
                  • M
                    @veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
                    I think this is software problem....
                    • M
                      @veye_xumm The manual is something wrong...
                      Pls check.
                      3.5.3 Download the bsp package to the Jetson board
                      On Jetson Board:
                      wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                      Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                      tar -xzvf nvidia_jetson_veye_bsp.tgz
                      But...
                      $ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                      --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                      Resolving github.com (github.com)... 20.200.245.247
                      Connecting to github.com (github.com)|20.200.245.247|:443... connected.
                      HTTP request sent, awaiting response... 302 Found
                      Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
                      --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
                      Reusing existing connection to github.com:443.
                      HTTP request sent, awaiting response... 404 Not Found
                      2022-08-15 20:03:06 ERROR 404: Not Found.
                        @maponarooo
                        Thank you for the reminder, I've modified it.
                        The file should have a tar.gz suffix instead of tgz.
