    SOLVED IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera
    3972
    • M
      maponarooo @veye_xumm last edited by
      @veye_xumm By any chance, does the IMX385 camera firmware version matter?
        @maponarooo said in IMX385 on Jetson Xavier NX JetPack5.01DP can't find camera:
        I do not think so.
        • M
          maponarooo @veye_xumm last edited by maponarooo
          @veye_xumm NVIDIA has replied, but I don't know the meaning...
          Pls explain what they say...
          **Please collect the trace log to check.
          Also be aware below for r35 release.
          Skew calibration is required if sensor or deserializer is using DPHY, and the output data rate is > 1.5Gbps.
          An initiation deskew signal should be sent by sensor or deserializer to perform the skew calibration. If the deskew signals is not sent, the receiver will stall, and the capture will time out.
          You can calculate the output data rate with the following equation:**
          https://elinux.org/Jetson/l4t/Camera_BringUp
            @maponarooo
            • M
                @maponarooo
                • M
                  alt text
                  alt text
                  New clock: GstSystemClock
                  Additional debug info:
                  Buffer pool activation failed
                  Caught SIGSEGV
                  Waiting for EOS...
                  What do I do?
                    @maponarooo
                    Please try
                    dmesg
                    check if any errors.
                    • M
                      What's the matter?
                      $dmesg
                      [ 22.356665] handlers:
                        @maponarooo
                        • M
                          Caught SIGSEGV
                          Waiting for EOS...
                          After, dmesg logs....
                          $dmesg
                          [ 153.865630] Call trace:
                          quad@quad-nx:~$
                            @maponarooo
                            Here is my suggestion that
                            • M
                              @veye_xumm I have tried my old jetPack 4.61 old image with same IMX385 camera board and Jetson Xavier. But it working well....
                              I think this is software problem....
                              • M
                                @veye_xumm The manual is something wrong...
                                Pls check.
                                3.5.3 Download the bsp package to the Jetson board
                                On Jetson Board:
                                wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                Or type in the address bar of your browser:https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                tar -xzvf nvidia_jetson_veye_bsp.tgz
                                But...
                                $ wget https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/latest/download/nvidia_jetson_veye_bsp.tgz
                                Resolving github.com (github.com)... 20.200.245.247
                                Connecting to github.com (github.com)|20.200.245.247|:443... connected.
                                HTTP request sent, awaiting response... 302 Found
                                Location: https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz [following]
                                --2022-08-15 20:03:06-- https://github.com/veyeimaging/nvidia_jetson_veye_bsp/releases/download/v1.08/nvidia_jetson_veye_bsp.tgz
                                Reusing existing connection to github.com:443.
                                HTTP request sent, awaiting response... 404 Not Found
                                2022-08-15 20:03:06 ERROR 404: Not Found.
                                  @maponarooo
                                  Thank you for the reminder, I've modified it.
                                  The file should have a tar.gz suffix instead of tgz.
