    SOLVED saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    3882
    • W
      watchever last edited by
        @watchever
        • W
            @watchever
            NO.
            • W
              And Yuv420 of course ?
                Yuv420 of course ?
                no,just yuv422
                • W
                    @watchever
                    These are software functions.
                    • W
                        @watchever
                        For yuv ,
