    SOLVED saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    3882
      RaspiCamControl
      I think it could not work.
      • W
          @watchever
          • W
              @watchever
              NO.
              • W
                And Yuv420 of course ?
                  Yuv420 of course ?
                  no,just yuv422
                  • W
                      @watchever
                      These are software functions.
                      • W
                          @watchever
                          For yuv ,
