    SOLVED saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    3882
      @watchever
      yes.
      • W
        • W
          • W
            Thanks for your help
              RaspiCamControl
              I think it could not work.
              • W
                  @watchever
                  • W
                      @watchever
                      NO.
                      • W
                        And Yuv420 of course ?
                          Yuv420 of course ?
                          no,just yuv422
                          • W
                              @watchever
                              These are software functions.
                              • W
                                  @watchever
                                  For yuv ,
