    SOLVED saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    3427
      @watchever
      We do not provide such an interface for the time being. This shell script actually calls the i2C read-write function implemented by the C language. It's all open source.
      It should be able to implement the method you are talking about.
      • W
        @veye_xumm,
        Ok I am going to implement this in C language.
        However do you know if there is a guide regarding the registers of the VEYE module on I2C, possible values and what they are doing.
        I see that there are common steps to set value using registers 0x10, 0x11, 0x12, 0x13, but not clear for me.
        Thanks for your help
        • W
            @watchever
            yes.
            • W
              • W
                • W
                    RaspiCamControl
                    I think it could not work.
                    • W
                        @watchever
                        • W
                            @watchever
                            NO.
                            • W
                              And Yuv420 of course ?
                                Yuv420 of course ?
                                no,just yuv422
                                • W
                                    @watchever
                                    These are software functions.
                                    • W
                                        @watchever
                                        For yuv ,
