    SOLVED saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    3882
    • W
      watchever last edited by
      • W
        Thanks for your help
          RaspiCamControl
          I think it could not work.
          • W
              @watchever
              • W
                  @watchever
                  NO.
                  • W
                    And Yuv420 of course ?
                      Yuv420 of course ?
                      no,just yuv422
                      • W
                          @watchever
                          These are software functions.
                          • W
                              @watchever
                              For yuv ,
