    SOLVED saturation, contrast, shutter speed, iso on VEYE-MIPI-462
    3427
      @watchever
      As PiCamera is a python package that fully rely on MMAL, do you know if it can work with your VEYE-IMX462 camera ?
      I think it could not work.
      • W
        @veye_xumm, thanks for answer. Is there any possibility to set camera params by using a structure from libdmipicam.so rather than using shell script.
          @watchever
          We do not provide such an interface for the time being. This shell script actually calls the i2C read-write function implemented by the C language. It's all open source.
          It should be able to implement the method you are talking about.
          • W
            @veye_xumm,
            Ok I am going to implement this in C language.
            However do you know if there is a guide regarding the registers of the VEYE module on I2C, possible values and what they are doing.
            I see that there are common steps to set value using registers 0x10, 0x11, 0x12, 0x13, but not clear for me.
            Thanks for your help
            • W
                @watchever
                yes.
                • W
                  • W
                    • W
                        RaspiCamControl
                        • W
                            @watchever
                            • W
                                @watchever
                                NO.
                                • W
                                  And Yuv420 of course ?
                                    Yuv420 of course ?
                                    no,just yuv422
                                    • W
                                        @watchever
                                        These are software functions.
                                        • W
                                            @watchever
                                            For yuv ,
