    13281
    • H
      hello @hello last edited by
      @hello
      New clock: GstSystemClock
      Setting pipeline to READY ...
      Setting pipeline to NULL ...
      Freeing pipeline ...
      root@hello:/dev# dmesg
      [ 4.451868] CPU1: shutdown
      [ 4.509501] CPU2: shutdown
      [ 192.439657] Enabling wake24
      [ 192.445718] Enabling wake53
      [ 192.474213] Enabling wake83
      [ 192.474222] Enabling wake29
      [ 192.486471] Enabling wake76
      [ 192.486473] Enabling wake77
      [ 192.486475] Enabling wake78
      [ 192.486477] Enabling wake79
      [ 192.486479] Enabling wake80
      [ 192.486481] Enabling wake81
      [ 192.486483] Enabling wake82
      [ 192.486520] Enabling wake73
      [ 192.555437] Enabling wake71
      [ 192.587463] CPU3: shutdown
      [ 192.619451] CPU4: shutdown
      [ 192.647445] CPU5: shutdown
      [ 192.652403] Entered SC7
      [ 192.652403] Exited SC7
      [ 192.658275] CPU3 is up
      [ 192.664019] CPU4 is up
      [ 192.669812] CPU5 is up
      capture channel
      root@hello:/dev#
      • H
        @hello
        关于这个提供下下载的链接吧?
        下载来源如下:
        这个不是最新的吗?
        另外使用新的dtb做法是直接拷贝覆盖吧?可要烧写步骤呀?
        • H
          @hello
          下载如下的dtb
          烧写更新完成后发现摄像头sensor都检测不到了???
            @hello
            dmesg | grep veye
            1. 请检测一下你的排线有没有插歪了的情况?
            • H
                  @hello 请问解决了吗?
                  • H
                    @hello 请问解决了吗?
                    谢谢
                      • H
                        刚试了很多次,不行,没效果
                          @hello
                          你在终端杀掉gst-launch-1.0进程也是可以的
                          • H
                            @hello
                            现在全屏都是预览的摄像头画面,退不出来,进不了终端
                              • H
                                好的,感谢,需要的就是这个
                                • H
                                  @hello
                                  已经通过建议方案2成功退出预览,问题解决,谢谢!
