    6641
      @aike 你现在i2c是通的,能识别到摄像头型号,对吗?
      • A
        aike last edited by
          @aike 试试这个
          #include "tl3588-evm.dts"
          &i2c1 {
                  status = "okay";
                  // pinctrl-names = "default";
                  veyecam2m: veyecam2m@3b{
                         reg = <0x3b>;
          	           clock-names = "xvclk";
                         status = "okay";
                         port {
                                  veyecam2m_out0: endpoint {
                                         data-lanes = <1 2>;
          &csi2_dphy0_hw {
          	status = "okay";
          &csi2_dphy1 {
          	status = "okay";
          	ports {
          		#address-cells = <1>;
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          				reg = <1>;
          				data-lanes = <1 2>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          			csidphy1_out: endpoint@0 {
          				reg = <0>;
          &mipi2_csi2_hw {
                  status = "okay";
          &mipi2_csi2 {
          	status = "okay";
          	ports {
          		#size-cells = <0>;
          		port@0 {
          			reg = <0>;
          			#size-cells = <0>;
          				reg = <1>;
          		port@1 {
          			reg = <1>;
          			#size-cells = <0>;
          				reg = <0>;
          &rkcif_mipi_lvds2 {
          	status = "okay";
          	firefly,yuv_camera;
          	port {
          		cif_mipi2_in0: endpoint {
          &rkcif_mipi_lvds2_sditf {
          	status = "disabled";
          	port {
          		mipi_lvds2_sditf: endpoint {
          &rkisp0_vir2 {
          	port {
          		#size-cells = <0>;
          		isp0_vir2: endpoint@0 {
          			reg = <0>;
          &gpio2 {
                  pinctrl-0 = <&mipidphy0_pwr>;
                  camera3-pwdn-set {
                          gpio-hog;
                          output-high;
          &pinctrl {
          	cam {
          			rockchip,pins =
          				/* camera power en */
          &rkcif {
          	status = "okay";
          &rkcif_mmu {
          	status = "okay";
          &rkisp0 {
          &isp0_mmu {
          • A
            aike last edited by
              关于dts的逻辑关系,你可以参考这篇文章。
              • A
                aike last edited by
                摄像头拓扑结构图
                摄像头拓扑结构图.txt
                抓取图片也有问题
                • A
                  aike last edited by
                  这是什么情况呢
                    • A
                      aike last edited by
                      同时串口会打印这些
                      请问这个问题怎么解决
                        • A
                          aike last edited by
                            @aike 可能性很小。你试试用这个脚本抓一下图:
                            • A
                              aike last edited by
                              • A
                                aike last edited by
                                nv12-1920x1080.yuv里面是空的
                                  @aike
                                  你试一下将驱动中下面这个函数改成如下:
                                      VEYE_TRACE
                                  		return -EINVAL;
                                  	//	return -EINVAL;
                                  	return 0;
                                  然后重新编译一下再测测。
                                  • A
                                    aike last edited by
                                    还是一样的错误
