    7225
    • A
      aike last edited by
        @aike 试试这个
        #include "tl3588-evm.dts"
        &i2c1 {
                status = "okay";
                // pinctrl-names = "default";
                veyecam2m: veyecam2m@3b{
                       reg = <0x3b>;
        	           clock-names = "xvclk";
                       status = "okay";
                       port {
                                veyecam2m_out0: endpoint {
                                       data-lanes = <1 2>;
        &csi2_dphy0_hw {
        	status = "okay";
        &csi2_dphy1 {
        	status = "okay";
        	ports {
        		#address-cells = <1>;
        		#size-cells = <0>;
        		port@0 {
        			reg = <0>;
        			#size-cells = <0>;
        				reg = <1>;
        				data-lanes = <1 2>;
        		port@1 {
        			reg = <1>;
        			#size-cells = <0>;
        			csidphy1_out: endpoint@0 {
        				reg = <0>;
        &mipi2_csi2_hw {
                status = "okay";
        &mipi2_csi2 {
        	status = "okay";
        	ports {
        		#size-cells = <0>;
        		port@0 {
        			reg = <0>;
        			#size-cells = <0>;
        				reg = <1>;
        		port@1 {
        			reg = <1>;
        			#size-cells = <0>;
        				reg = <0>;
        &rkcif_mipi_lvds2 {
        	status = "okay";
        	firefly,yuv_camera;
        	port {
        		cif_mipi2_in0: endpoint {
        &rkcif_mipi_lvds2_sditf {
        	status = "disabled";
        	port {
        		mipi_lvds2_sditf: endpoint {
        &rkisp0_vir2 {
        	port {
        		#size-cells = <0>;
        		isp0_vir2: endpoint@0 {
        			reg = <0>;
        &gpio2 {
                pinctrl-0 = <&mipidphy0_pwr>;
                camera3-pwdn-set {
                        gpio-hog;
                        output-high;
        &pinctrl {
        	cam {
        			rockchip,pins =
        				/* camera power en */
        &rkcif {
        	status = "okay";
        &rkcif_mmu {
        	status = "okay";
        &rkisp0 {
        &isp0_mmu {
        • A
          aike last edited by
            关于dts的逻辑关系,你可以参考这篇文章。
            • A
              aike last edited by
              摄像头拓扑结构图
              摄像头拓扑结构图.txt
              抓取图片也有问题
              • A
                aike last edited by
                这是什么情况呢
                  • A
                    aike last edited by
                    同时串口会打印这些
                    请问这个问题怎么解决
                      • A
                        aike last edited by
                          @aike 可能性很小。你试试用这个脚本抓一下图:
                          • A
                            aike last edited by
                            • A
                              aike last edited by
                              nv12-1920x1080.yuv里面是空的
                                @aike
                                你试一下将驱动中下面这个函数改成如下:
                                    VEYE_TRACE
                                		return -EINVAL;
                                	//	return -EINVAL;
                                	return 0;
                                然后重新编译一下再测测。
                                • A
                                  aike last edited by
                                  还是一样的错误
