    SOLVED 相机驱动
    12004
      lin @veye_xumm last edited by
      @veye_xumm 主板roc-3588s-pc,相机是AR0234M
        veye_xumm @lin last edited by
        @lin 这个现在不支持isp_mainpath.
          lin last edited by
          那无法获取到经过isp处理后的图像吗?
              @veye_xumm好的
                lin last edited by
                &i2c7 {
                status = "okay";
                    compatible = "veye1,mvcam1";
                    status = "okay";
                    reg = <0x3b>;
                    clocks = <&ext_cam_clk>;//?
                    clock-names = "xclk";
                    port {
                            data-lanes = <1 2>;
                  lin @lin last edited by
                                  @veye_xumm !是i2c7
                                  @lin said in 相机驱动:
                                      @lin said in 相机驱动:
                                      不好意思,我之前说的就是SYS_RSTn引脚的意思。
                                      拍一下你硬件连接的照片我看看。
                                          @lin said in 相机驱动:
