    SOLVED 相机驱动
    12009
      veye_xumm @lin last edited by
        lin @veye_xumm last edited by
        @veye_xumm好的
          lin last edited by
          &i2c7 {
          status = "okay";
              compatible = "veye1,mvcam1";
              status = "okay";
              reg = <0x3b>;
              clocks = <&ext_cam_clk>;//?
              clock-names = "xclk";
              port {
                      data-lanes = <1 2>;
            lin @lin last edited by
                            @veye_xumm !是i2c7
                            @lin said in 相机驱动:
                                @lin said in 相机驱动:
                                不好意思,我之前说的就是SYS_RSTn引脚的意思。
                                拍一下你硬件连接的照片我看看。
                                    @lin said in 相机驱动:
                                          @veye_xumm 测量没反应?
