    SOLVED 相机驱动
    8540
      lin last edited by
      那无法获取到经过isp处理后的图像吗?
        veye_xumm @lin last edited by
          lin @veye_xumm last edited by
          @veye_xumm好的
            lin last edited by
            &i2c7 {
            status = "okay";
                compatible = "veye1,mvcam1";
                status = "okay";
                reg = <0x3b>;
                clocks = <&ext_cam_clk>;//?
                clock-names = "xclk";
                port {
                        data-lanes = <1 2>;
              lin @lin last edited by
                              @veye_xumm !是i2c7
                              @lin said in 相机驱动:
                                  @lin said in 相机驱动:
                                  不好意思,我之前说的就是SYS_RSTn引脚的意思。
                                  拍一下你硬件连接的照片我看看。
                                      @lin said in 相机驱动:
                                            @veye_xumm 测量没反应?
