    SOLVED 相机驱动
    12006
      lin last edited by
      &i2c7 {
      status = "okay";
          compatible = "veye1,mvcam1";
          status = "okay";
          reg = <0x3b>;
          clocks = <&ext_cam_clk>;//?
          clock-names = "xclk";
          port {
                  data-lanes = <1 2>;
        lin @lin last edited by
          veye_xumm @lin last edited by
            lin @veye_xumm last edited by
                        @veye_xumm !是i2c7
                        @lin said in 相机驱动:
                            @lin said in 相机驱动:
                            不好意思,我之前说的就是SYS_RSTn引脚的意思。
                            拍一下你硬件连接的照片我看看。
                                @lin said in 相机驱动:
                                      @veye_xumm 测量没反应?
                                          • 0
                                            023 @lin last edited by
